Does anyone know what the maximum electrical output is for the R3 versus the average draw. I am thinking of adding a few accessories. Thank you Lee
The alternator is rated at 37 amps min. at 2,000 RPMs and 41 amps min. at 6,000 RPM.
37 amps x 12 volts = 444 watts or 41 amps x 12 volts = 492 watts
A common operating load for a standard fuel injected bike is about 285 watts.
This reference should help you as long as you know how many watts your gear and lights draw.
http://www.powerletproducts.com/docu...scapacity.html
If you are adding very much you might want to consider an aux fuse box.
