Hi Jim,
Triples have their proper filter between pump and crank, standard automotive style, Triumph and BSA advised oiling a new filter element and filling as much of the crankcase filter cavity as possible. My T100 has an aftermarket filter kit with the same element, in the return line between engine and oil tank; I haven't ever considered not filling the filter container with oil after changing the filter. About the only filter elements that don't need specific pre-filling are the ones in the bottoms of OIF, because filling the frame fills a filter element in that position.
Hth.
+1. And, after starting the engine, there's a longer time 'til you can be sure oil is or isn't returning to the tank.
Hth.
