A tip to gbc and others on doing close up photos and dealing with shiny bits. Don't use the flash. Turn it off. You could also try using a darker background for the photo that has a flat finish, but that is not a must. For gbc's pic, just turning off the flash would have probably given the bolts more detail and depth.
The other trick is to shoot them at a slight angle so that any reflected light does not wash out the nice shiny finish. As you look thru the view finder, try to see something reflected in the part. Then you know that you probably will not have any glare.
They came out nice, gbc. If you want those same bolts to look original, just bead blast them.
regards,
Rob
regards,
Rob
