1 - 20 of 2299 Posts
Havn't seen this come around in forever so:
Washed it, toothbrush style, shes cleaner than ever :)
Then I got motivated and put on my new sprockets going from 19/44 to 18/46....
OMG I AM IN LOVE AGAIN! It lifted the front end in 3rd gear :eek:
CRAP !..........found a staple in my rear tire!.Now riding the TT600 for a bit while Mr Pirelli sends me two new "Angels" for my Daytona . Hope they work as well as they are supposed from all the reviews I've read.
Put the plate, indicators and rear taillight back on. Hooked the headlights up and peeled the tape off. Reinstalled the mirrors.
Put her back into street mode.
I changed the plugs in the D12 on Saturday, now I can smell gas. The hoses on the gas tank didn't have any clamps on them so I should probably put some on. The new plugs made a big difference in how the bikes working though.
No clamps wow! surprised they haven't leaked before. I think I wuld put some on myself. Just a thought , Ed
I think I need to look at my fuel tap also, when I took the tank off, the fuel wouldn't stop leaking out of it in the off position.I sure don't like getting gas all over everything:mad:
I thought I had some of the little spring clamps for your fuel lines around here to send you, but it looks like they've fallen into the black hole in the garage. You might want to pick up new fuel line hose also as the old ones maybe hardening.
Sometimes it's two steps forward and one step back when working on older, well anything. ;)
Brad
I did a 1 month-ish checkup on the R/R upgrade, all is good,, tried to find my front tires slow leak, no luck. Carbon fibered my windscreen, shaved the badges off the fuel tank, buffed, then carbon fibered the top of tank and started designing my tank pads. One of these days ill figure out my lowbeam HID issue. Topped off oil, took for a 10 min ride and put her to bed :)
Sent from my T-Mobile G2 using Motorcycle.com Free App
Brad... good idea about changeing the fuel lines. Should the fuel tap stop leaking when it's shut off, when I remove the fuel tank. If so, might there be something stuck in it, or do they need to be rebuilt from time to time:confused:
Chris
what are the settings on the tap? on, res, prim? or does it have off? if it has no off it's a vacuum operated tap and could be the diaphragm has failed.
