Eventually and ideally, i'd like to have all 3. From other posts here, I've learned that getting the carbs before the big bore kit is preferred. But what if new Cams for the 865cc engine is thrown into the mix. Which is the biggest bang for the buck?
FCR39 and the TPUSA cams are about the same price. The Wiseco 904 bore kit is a bit cheaper. Or should I just go straight to the HSR42? These mods probably won't be happening soon, but I want to plan/save appropriately. So, to sum it up, should I go:
1. Stock 865 with FCR39 (or Mikuni)
2. Stock 865 with TPUSA cams
3. Wiseco 904 with CVK36
Thanks!
Thanks!
