2002 Tiger, typical ran on battery until it died problem
I went though the electrical checks here and diagnosed the regulator as the problem and got one from Ricks.
I installed the regulator and replaced the female bungs for the fuel injection tank while I was at it. They had been leaking when I took the tank off for maintenance before.
Put it all back together and it will not start. It will turn over strong but will not fire.
Took it back apart and got out the trusty test light. Hooked the battery back up and tested for signal at the coils and the injectors while cranking and got it.
Took out the new bungs from the tank and double checked them, they work fine. Listened for fuel pump engaging, it runs when the bike is turned on.
Reading another thread I will test the main power relay and the side stand switch tomorrow, but is there anything ELSE I should be looking for?
Thanks!
DustyKat
Thanks!
DustyKat
