I thought that I'd already cured this problem 6 months ago.
History :- I had started to notice condensation on the inside of one of my headlights after washing or riding through a downpour. I assumed it must be a cracked lens but couldn't find a crack. I took the unit out and all looked fine. I filled it with water to try and find where the water was getting in. The reflector is fitted to the glass using a type of resin. Water was seeping through this resin. After drying it all out thoroughly I knocked up some epoxy resin and applied liberally over the leaking area. When thoroughly dry I reassembled, chuffed with myself at such a simple cure (no pun intended).
This has worked fine until now ! The condensation is back. Noticed it after last wash ( only a garden hose not a pressure washer ). Has anyone any ideas what to use this time, or dealt with this problem any other way ? It seems a waste to buy a new unit when this one works perfectly well.
Thanks in anticipation, JJ.
Think about this a little more carefully. Most Epoxies are water proof, but they're usually not that good with heat. Your headlight will get pretty darn hot on the inside of that epoxy seal.
Look for a sealant that can be used in high temps as well as in water and you'll probably find a permanent cure.
Mick :cool:
