1 - 2 of 2 Posts
I’ve developed a few oil leaks (one from the line that goes from the sump to the cooler, and I think the one on the shifter).
They aren’t major leaks, but I wanted to ask you folks if you thought this was something that could be covered under Triumph’s standard warranty?
TIA
I'm not sure about what the standard warranty covers, but I would think that faulty oil seals would be covered, at least on the oil cooler which isn't a 'normal wear' part. A note on the shifter shaft seal: before fretting about it being a faulty seal, make sure it isn't oil from the chain collecting there, as this usually happens with mine after oiling the chain.
1 - 2 of 2 Posts
