1 - 20 of 50 Posts
So once again I'm in a great debate with two state's DMV's trying to get my title right. The title is wrong in the fact that there should be a G, instead of a C. I can see the problem there. When I try to decode the VIN I find that a lot of contradicting information on my 1993 D1200. I know that the bike was brought to the US pre-1995. I'm kind of lost on this other than I want the letters changed to indicate the model year is right in the title. I'm starting to get worried if I can't get this issue fixed I may have a perfectly good illegal motorcycle. I mean these are not track bikes either:(
Care to refresh us on the whole affair, and maybe give us the VIN? (You can always change the last 3 or 4 digits to x if you don't want to give up the exact VIN.)
I'm a bit confused, as "C" denotes either 1982 or 2012, "G" is '86 or 2016, and none of those years are a match for your ride. Are you looking at the tenth digit for year? A '93 bike should have a VIN that reads something like "SMT3xxxxxPJ00xxxx" or "SMT3xxxxxPJ01xxxx". A '92 would be "SMT3xxxxxNJ00xxxx", '94 would be "SMT3xxxxxRJ0xxxxx". (I'm pretty sure the 1200s have a 3 at digit 4, but I'm curious as to whether its a 4 instead.)
(No, I still haven't found a job. Why do you ask? :p )
-Kit
Reading the VIN right off the plate it is, "SMTTTC354CGPXXXXXX. I found somewhere that stated with UK VIN's the 11th position is the model year, which P would be a 93 using the regular system. I'm pretty much lost and still waiting for a call from Triumph to make sure this is the right VIN.
Are you sure that's the VIN? Maybe you're reading the engine number? The VIN should be on the headstock and maybe on a plate under the seat, but the engine number is not the same. (Though IIRC it's close enough to be confusing.)Anyway... I get 18 digits there, but even if that's a typo your number confuses me. Here are mine, decoded:
SMT 375DF 2 T J 037xxx <-- '96 Trident
SMT 605FS 5 4 J 183xxx <-- '04 Sprint RS
SMT = England, Triumph
375DF / 605FS = Model and trim (Trident / Sprint RS)
2 / 5 = Check digit
T / 4 = Year (1996 / 2004)
J = Factory
Last 6 = Vehicle serial number
You can see here that they had a factory code at digit 11 long before they had multiple factories, and were certainly running the standard "model year at digit 10" scheme at least as early as '96. (And if you really want to get dorky, note that my '04 model year RS was assembled in May of '03. The tenth digit is definitely *model* year.)
Maybe there are UK folks who could post up their VINs? Daytona750, maybe? I think you have the earliest bike on the board. Anybody else with a pre-'95, or any UK VIN we could see for comparison?
-Kit
Just for comparison, here are some eBay VINs:
SMT 900K1 1 8 T 339584 - 2008 Bonnie, "T" for Thailand
SMT 915RN 2 8 T 333764 - '08 Speedmaster, also Thai
SMT 502FK 3 W J 065102 - '98 T595 Daytona, made in England
SMT 380DH 2 S J 028273 - '95 Sprint
ZDM 1HB6R 3 N B 004011 - 1992 Ducati 851
ZDM 1SB5T 9 1 B 011330 - '01Ducati 996
ZDM 1LC4N 0 R B 014781 - '94 Ducati 900SS
WB1 04370 3 D 6 308000 - Listed as a 1984 BMW R100RS, but the VIN says it's actually an '83.
WB1 05360 5 R 0 301125 - '94 BMW K1100LT
JH2 RC430 3 R M 002226 - '94 Japanese Honda Magna, Hamamatsu factory
JH2 SC300 7 R N 000849 - Fails check! But, if we change the "N" to an "M" it becomes a '94 Japanese Honda CB1000 built at the Hamamatsu factory
1HF SC226 4 R A 600885 - '94 American Honda Gold Wing 1500, made in Ohio
So you can see that these numbers actually carry a meaning, and the 10th digit should be an "R" for a '94 VIN no matter where it's built.
Okay, I'm off to see if I can get a life on eBay....
-Kit
Discussion Starter #8
Yeah that's the actual VIN, I really appreciate everyone's participation on this. Flying Custard thanks, your VIN aligns with mine except for the year. Now I have to convince the DMV that when I go to title it, it is in fact a 1993 and not an 1986 as the C would classify it in the States.
Mines a 96 750 Trident SMTTC333BET
Roger
Discussion Starter #10
Sorry Kit, I added an extra x than I should have, it's a 17 digit number. Well atleast no I know my stuff is legit and it was personally imported to the States at some point before 2000. I really hope I can get this title issue fixed. I'm running into the problem that I'm in the military and want to register my Daytona in Pennsylvania (home) so that I never have to change states again, until I'm out of the service which is still a long way away. Thanks for everyone's help it's now a fight between Florida and South Carolina.
Weird!!! Well, now we see that the UK VINs definitely do use digit 11 for year and don't use the factory code, at least through '96. Any of you guys in the UK got a newer bike in the stable? Now I'm really curious about this...
Good luck with your reg woes, ffry63!
-Kit
Bonnie T100
Hi,
I bought my brand new bike in Chile on march 2009. I have been trying to decode the vin number, specially the model year. Most of posts here state that "10" digit is the model year. Well, it does not work to me:
My VIN: SMTTJ9157G836xxxx
G: 1986 or 2016...
I have never given VIN a second thought, nor am I about to. However, 1995 was the first year for official import of Triumphs to the US of A if I'm not mistaken.
SMT TC396 JMX... '99 Legend, 11th digit year 'X'
(...now where are those job ads..:D)
Kit, I tried to help someone in the UK decode their VIN and it just didn't come out right at all using the 'International VIN' decoding. It seems 'home' market VINs are slightly different from the international and some contries still use the manufacturer's home market pattern.
Engine number prefixs are also different whereas in the US, and maybe else where, we have something like SMT502F... prefix, in other contries it may just be a single letter.
Brad
Discussion Starter #17
Yeah, the VIN issue is no fun, as you all can see I've had problems for almost a year now. I think it has come down to me going to the DMV and choking someone until the damn alphanumeric character is changed, or do the more sensible thing and go to the local congressman/woman and get this crap fixed. I'm moving to Nevada in less than a year and I am really getting pissed because South Carolina's DMV is a effing joke.
Good luck to all of those that have UK Vin issues.
Hi ffry63.
My bike is a 1993 model year 900 Trident, possibly built in 1992. It's a UK bike. VIN is SMTTC338DDP0056** The Engine no. is 0057**
Andy.
Hi frry63,
I think you have added an xtra T in your Vin, here is your Vin with the Xtra T removed.
This makes the P the 11th character in the VIN and correct for a 1993 model.
SMTTC354CGPXXXXXX
Hope this makes it all correct for you..
Sweenz
Discussion Starter #20
I noticed I did add an extra spot by mistake. I know the VIN is clear it's just that the South Carolina DMV is caught in too much b/s to help me. Their clerks have even seen the correct VIN and still shrug their shoulders. It's either going to comedown to me bribing someone, writing my congressman (doubt it will do anything), or unfortunately selling the Big D for basically nothing.
1 - 20 of 50 Posts
