I just installed a veypor on my bike... it's RAD!!
took about 2 hrs to install (most of which was figuring out which wires coming out of the ECU are coil signals)
I tapped into the rear light power so it turns off with the ignition instead of having to be unplugged when you're done riding. in addition to having a working speedo again (!!!) it's got a tach a gear indicator, gas gauge and dyno functions (all these are calculated from a combo of odo, speed and rpm readings)
I'll post pics later.
