hi ventura
your work on this link http://www.triumphrat.net/twins-technical-talk/103145-modded-scram-dyno-results.html
looks great...if you still want to do any tests try aluminium velocity stacks on the original airbox...just throw out those rubber parts and close the rest with silicone or any rubberplate
because of the step in the stock rubberparts there is no good airflow and it causes interferences...throw out the difference plate between head and intakes and use 70mm long velocity stacks
look...here´s a pic on stock airbox but with fcr´s...scroll down and click on third and fourth pic:
http://www.classicbike-raisch.de/html/motor_vergaser.html
you will have to dremel a little bit on the diameter at the box to make them fit...but stock rubberparts will refit so that there are no gaps
there are two versions...50mm for the thrux and bonnie for better reving and torque at high revs...70mm for the scram because of more torque at low revs...i can go get them for you if you don´t find in UK
cheers
twinfan
cheers
twinfan
