1 - 3 of 3 Posts
Does anyone know if the EFI throttle bodies have the same 52mm inlet flange as the stock CVK carbs and CR-II racing carbs?
/M
The same pod filters are used on carbed and EFI bikes, that is 54 mm, so I'll bet they are.
They also share the 60mm screw clip that holds the airbox sealed against the carb/throttle bodies, according to parts listings.
PM me if you need some velocity stacks for your stock carbs.
I have extra ones
They do not have screens like the photo you posted.
If your shopping generally the 55mm is what fits
1 - 3 of 3 Posts
