My 955i Tiger has now done 7,000 miles and is 2 years old (owned from new). I do all my own servicing and checked the valve clearances at the weekend.
I found 2 exhausts and 3 inlet clearances 0.01mm wider than the tolerance specified by Triumph. Although I have a shim removal tool, I couldn't be bothered having the bike in pieces for a week while I sorted out what shims I would need and hence bolted it all back up.
My past experience of overhead cams is that the clearances tighten with miles rather than slacken. If so, this would mean that the clearances must have been wider from new. Also if I leave them they should eventually go into tolerance.
Anybody got any comments on my observations? Or should I be stripping it down again and doing the job right?
Regards
Chris
Regards
Chris
