I'm looking at updating the map on a '13 Bonnevile SE EFI (VIN 5932xx, engine 5944xx) with aftermarket cone slip-ons and no other mods currently. It looks like 20507 is the most likely candidate on the TuneECU site, but I see that it's for "up to" E25, which is Brazil, right? Is there a better map for aftermarket exhaust, LCD odo, and E10?
I'd eventually like to do SAI and 02 delete and upgrade the airbox snorkel, what would be the best map for that? Should I spring for a TTP map at that point?
Try 20505 or 20507 and just see what your butt dyno tells you
I would probably say 20505
From TTP he will guide you as to what is best for your config, whatever that be and you can be assured that you have something dyno developed specifically for that
Pretty good value if you consider what an actual custom dyno session would cost
I think I got hung up on the "Arrow 2-into-2" vs. aftermarket silencers which is what led me to rule out 20505, but after looking again I see that 20505 is for E10, so I'm inclined to agree with you.
