1967 triumph bonneville- frame number SJ6150PA. Motor number matches the frame.These are original, not fakes. I can`t find anything that list`s those letters/numbers.Everything I read says DU44---to Du66---.Is it possible it`s a UK bike? It`s appears to be mostly original except for the tank and possibly the rear fender.
Anybody have any ideas? Thanks, Mike
In the post 69 numbering system, there is no 'S' ... and I have no idea what the 'PA' at the end is ... This is a false serial number ...
if you have a title with a matching number, I'd forget about it ...
numbers
Also stamped on the motor above the serial # is T120R.There is no signs of doctoring or grinding of the areas.Why the comment about if the title #`s match to forget about it? I find it hard to believe that the frame / engine and title have all been stamped to someones liking.I found a casting number on the frame backbone that is 4 digits with the last 2 numbers being 67.
Trumph serial numbers never included the year in corresponding digits.
I think t100rc means that if the numbers on the bike match the numbers on teh title, forget about any future problems. He's probably right.
http://www.tioc.org/serial_numbers.htm confirms that the letter "S" was never used in the post-69 numbering scheme.
Good, detailed pix will help narrow down the year model, but it's probably a re-stamped "bitsa" made from 2 or more different bikes, and since parts can be mixed from '53 to '83, anything goes.
