G
Hi,
I changed the spark plugs last weekend.
When removing the tank I found one hose disconnected (It probably came off when I removed the tank)
It comes straight from the RCU and I guess to belongs into the Airbox but I'm not exactly sure since I did not see it before.
Could anyone confirm or correct please?
David
Are you speaking of the hose that routes back to the computer and has a plastic corrugated cover on it? If so, it plugs into the airbox on the right side. There is a right angle adapter on the box, and it goes there.
It is a hose for the barometric pressure sensor.
It's item 20 on the airbox diagram here:
http://www.bikebandit.com/triumph-motorcycle-sprint-rs-2001/o/m17615
G
Exactly that's the one!!!
May thanks. Excellent service.
Also thanks for pointing me to this page. Really good to know.
David
