I just inspected my rear pads and the pad nearest the pistons has worn twice as fast as the outer pad - i.e. the outer pad had almost no wear at all and the inner pad was half of it's original thickness.
These are EBC double H sintered pads that I installed 4,500 miles ago.
I cleaned the caliper, used a little of that brake caliper grease (for the first time), and installed a new set of pads.
Any ideas on what would cause this? I was on a long road trip when I last changed the pads, so I didn't clean the caliper or use the grease the last time - could that have screwed something up?
P.S. my front rotor is warped, and I just read a bunch of posts on the subject. Back to the dealer!
