According to the wiring diagram for export models from DU66246 to DU90282 (1968), there`s no direct connection from the battery to the rectifier.
Starting from the battery negative (-), a brown/blue goes to the fuse and then to the ammeter.
Through the ammeter, then it changes colour to brown/white. and further on to the ignition switch.
The ignition switch has another link (br/wht) which goes to the bridge rectifier (-ve).
Here there is another brn/wht link to the zener.
Remove the fuse and with the ignition switch OFF, multimeter on the resistance (Ohms) range, measure the resistance at the brown/white wires.
Should be a few Kohms. [in other words not a short circuit]
All earth (+ve) wires are red.
