Hi All, Need to learn about this regulator. I was told it's not really old. It has the dark brown potting material, not clear green like in new parts sellers photos.
What I really need to know is what is the wattage rating.
Will it handle 2 wire Wassell/Emgo 16A 200w two wire stator?
Has normal Lucas rotor with date code of 11/99
If it cannot handle the watts of the "special" high output 2 wire, what would happen?
Would/could it cause stator to overheat & melt?
Charging is working fine, battery is 12.67v & has no low voltage or running issues of any kind.
The new Tympanium is rated at 200w, but what about this one?
Thanks, Don
Thanks, Don
