1 - 7 of 7 Posts
I'm in the process of installing aftermarket turn signals on my '08 T100. Considering my lack of experience and knowledge in electrical wiring, I realized it would probably be helpful to have a wiring diagram available. However that is not the case. I'm going out on a limb here and making an assumption. Because the white wire of the stock signal plugs into the striped wire of the harness, this would be the "Ground" and the black wire of the stock signal would be the "Hot" wire? Can anyone confirm?
Chris
So if I'm understanding correctly regarding wires on stock turn signals:
White = Positive?
Black = Negative?
Signals
Just did my RR's yesterday- it is simple!!.. When you want to do the RR light- thats a bit more ionvolved if you do the Lucas unit! HOWEVER all finally went well & it looks awesome!!!
++ on all above as pos etc..
Many thanks
Thanks guys. I managed to get them mounted and wired up. They're working like a charm. :)
Bike looks nice Blues. I am going with the same lights in amber only mounted under the headlight with the Thruxton bracket. The ones that Bellacorse sell are dual filament...NB are single filament so went with the Bellacorse sport lights so I can have running lights.
George
1 - 7 of 7 Posts
