1 - 2 of 2 Posts
I blew a fuse (the one for turn signals/break light/horn) a week or 2 ago and replaced it, but my right turn still signals don't work. I looked over my splicing and wiring and it seemed good. I checked the bulbs and they seem all right.
Before I take it to the dealer Friday I wanted to see if anyone had any ideas for what to check or try first. The only idea i have left is to try the wiring with a different set of lights.
If you have bulbs check those.
If you don't, try a different set of lights.
If that doesn't work, triple check that the wiring is correct.
If everything checks out at the signals and with the wiring, check/replace the flasher relay.
If, after everything, your turn signals still don't work, the switch is bad.
I worked on a truck yesterday that needed a fuse, bulbs, and a flasher.
It was ridiculous. 20 minutes of time to get a couple lights to flash.
The guy who drives the truck just putts around in a parking lot fixing sprinklers and only drives on the street to get gas. Doesn't even NEED turn signals.
1 - 2 of 2 Posts
