Just wondering if anyone knows where the turn signal relay is located on the bike. Im installing a new one for my new led brake and turn signals thanks
Are you installing an integrated tail light? Because, otherwise I'm confused as to why you'd need to find the turn signal relay to replace one LED brake light with another.
To slow the flash rate of LED turn signals to DOT spec rather than installing resistors an easier and IMO better solution is to replace the mechanical flasher unit with an electronic one.
any chance anyone knows what the pin layout is on it? i am now doing a similar thing to my streety
