Im having trouble getting TuneECU to connect.
My setup:
sprint 955i ST 2000, sagem 1000 ecu. vin 98928
windows 10 running in Bootcamp on a 2016 64k macbook
lonelec cable with FTDI drivers downloaded from their site (have also tried a cable from triumph twin power so im sure issue is not the cable)
TE version 2.5.8
have reloaded drivers several times, Windows reports FTDI version 2.12.6.0 is loaded now
battery fully charged and on tender, fuse 9 removed, igntiton and kill switch on.
when I try to connect I usually see a red blinking light then I get a "could not connect" message saying turn ignition on and off. sometimes it connects and I get a weak flickering green light and see my VIN number etc. However, I have never been able to read the map.
Given the intermittent symptoms it feels like a bad connection or low voltage. I tried cleaning the two connecters to the ecu and the obd.
I also tried the Android version of TE but could not get that to work either. Hence I assume the problem is at my bike side.
Any suggestions?
My setup:
TE version 2.5.8
Any suggestions?
