1 - 20 of 680 Posts
edit
Loads of interesting stuff here, quite fancy doing some edits to the map with tune ECU if I can trust my cheap Chinese tablet not to screw up the download halfway through and brick my ECU:surprise:
How are you monitoring the AFR, have you done the fuelling changes on a dyno or on the road?
Is it possible to use the feedback from the O2 sensors via Tune ECU to monitor the afr at idle, I understand the O2 sensors don't come into play at full throttle so how do you monitor the afr then?
can you be certain that the engine is safe to run at 7800 RPM, I know that's still a relatively low speed but there is no other higher revving engine in the range to go off.
You say the throttle is reduced to 80% after 6500 RPM, do you think triumph did that to soften the impact of the rev limiter as you got close to 7000 RPM?
If you've removed this 80% restriction how easy would it be to alter the throttle mapping over the full range, equivalent to fitting a quick action throttle cam on a cable bike.?
Sorry for all the questions but this opens up a whole new world of possible modifications and also ways to completely screw up your bike of course:grin2:
  • Like
Reactions: Wolfmanhawaii
Hello Danielle,
I saw you on Facebook, and i am galde to see you here too.
Many many thanks for your work, for your time to build this map, and for sharing it to us.
I will use it on my thruxtonR as soon as i received my ODB LX
Can I use TuneECU on my 2017 Street Twin/Cup to disable the O2 sensors and nothing else? Just turn them off, and then tune the bike properly with the PC-V that I have on order?
If so, how would I do that? Connect with my BT module and Android phone, download the current map to the phone, save it, change a setting for the O2 sensors and then push to the ECU? This can be done on a newer bike without locking the ECU?
At this point, they can now tune all the watercooled bikes. You are correct on the process. It can't read the map on your bike over bluetooth, only upload to your bike.
I'm 47 reprograms into my ECU so far, it hasn't locked me out yet. Keep in mind that this can import PC-V tables, thus negating the need for one entirely. You could install it, tune your bike, get the data and sell your power commander.
Having looked at the maps for the Street Cup, without a camshaft upgrade, there is barely anything at all to be gained with a PC-V. It's camshaft limited.
I have the TEC Cam installed, K&N air filter, de-snorkel and x-Pipe installed...
Running an AFR of 11 down low, and 14.6 up top at WOT... Definitely needs a tune. Gonna do that with the PC-V but if we want to tune the closed loop area we need O2 eliminators, or simply disable them with TuneECU like I have done on older bikes that allowed it.
Discussion Starter · #8 ·
ah that's right! I recall seeing your stuff. I've been following it with great interest, as my first bike was a Street Scrambler, and I really admire the Street Cup.
It's a neat little bike. It makes over 100hp less at the wheel than my other bike, but I love it, it's a blast.
I just need to disable the O2 sensors so that my long time tuner can work his magic with the PC-V as he has done with 20+ of my other bikes over the years...
Thanks for taking time out for the very in-depth response to all my questions, I'm going to have to go through it a few times to make sure I fully understand everything and maybe do my own reading up, I might have some more questions later if that's ok.
I presume you can download these maps to your device and play about with them offline in tune ECU just to find your way around the tables and learn how to modify the data without even connecting to the bike?
The one thing that does worry me and is probably the same for a lot of people on here is doing something irreversible to the ECU, I know there are fault codes listed that relate to the the ECU being locked. Putting aside any changes I make to the maps how foolproof is the actual process of just downloading and uploading maps to and from the ECU, have you personally heard of any horror stories. I've done it years ago on my older 06 Daytona with a cable connection but obviously these latest ecu's have a lot more security aimed at preventing customers from changing the map data, either triumphs own decision or forced on them by emissions legislation.
Out of curiosity I know you've done the majority of this work without a Dyno but do you plan on putting it on the dino now it's finished to see what gains you have made and maybe double check the afr, I know you've talked a lot about the feel and drivability of the bike and this does not always show up on the dyno.
Thanks again:grin2:
  • Like
Discussion Starter · #11 ·
my one advice is despite it being bluetooth, keep your device right next to the adapter. I had two failed uploads that were both due to it being at my workbench rather than at the bike, even though the bike was next to my bench.
If you **** up, you can always put the stock tune back on it. You can work on it offline, as it is never actually reading the tune that's on it, but rather working with the file you have open on your device.
I really am the first to go about this on this platform, so no horror stories yet. Caution is required. I've been very cautious with any changes. If something says it's 20% off, don't pull 20%. Pull 2% or 4% and observe the change. Small moves only to stay safe.
Thanks again:grin2:
You ask if the bike is going to be put on the dyno to see the gains. i assume you mean hp and torque? .... forget the dyno figures. Unless you have run the bike on that dyno before and have a bench mark they mean nothing.
What i do agree on from op is that fact that it's been tuned for rideability. In my opinion thats all that matters. .i have worked my thruxton probably more than most and will be getting it on the dyno for a complete tune with tune ecu on the 8th of october.
Pretty excited to.finally get the rev limiter lifted and throttle restrictions removed .
Sent from my SM-G975F using Tapatalk
For all we know the OP may have dyno figures before he did the tune.
Id be more interested to see the the improvements in the afr as my bike has been decatted/Vance and Hines and obviously still has the standard map, I'd also be interested to see the shape of the power and torque curves as it approaches the old rev limit and the new one.
I know how the bike feels is the most important thing but unfortunately we can't feel that sitting here.
So let me ask... This mythical "V&H Tune" that used to exist for the Street Twin/Cup... Is there a TuneECU copy of that somewhere that I could load it? I know that the dealers no longer push it, likely because of emissions legislation... but if that tune exists, can TuneECU flash that to the bike?
What I am frustrated with is how TuneECU went to Android, forcing you to work on smaller devices. But apart from that, it simply doesn't seem to work. I have the correct BT adapter, I can plug it in, pair it to my Galaxy S10 Plus and the TuneECU connects, talks to the ECU, can read the sensors and reset adaptations and all sorts of things... but there is no option to open a map on the phone, or push the map to the bike, etc...
When I use that BT adapter to connect to my 2018 Aprilia Tuono, it allows those things... I can read the map, save it, load it onto the phone and access the fuel tables and options, etc... I can then make changes and stuff, or push a map to the bike's ECU...
None of those options are here on the Street Cup... it's very limited in what it can do it seems...
Discussion Starter · #16 · (Edited)
It is available but it has nothing to do with emissions. The map is 100% identical in the timing curve, 100% identical in the air fuel ratio commanded, same exact throttle mapping, same idle speeds, same crossover point for the fuel tables.
The only difference is that the fuel tables and the load tables (which correlates to fueling based on map sensor data) give a little bit more fuel in some spots, but it also takes it away in others. It's not a lot either. The key takeaway is that the timing is identical so there's not any more power. It's just that the bike ran slightly better if it had the high-level exhaust and was still using the stock tune.
Attached is the main fuel tables for each cylinder. The areas in grey are identical between the two maps. The areas in color are different between the two. But it doesn't mean that fuel is added, because in some cases fuel is also taken away.
Either way it is a net gain of zero for horsepower.
you can do better by simply going to power commanders website and downloading their power commander tables for a Street Twin with full exhaust, because at least then you'll be gaining timing as well.
Discussion Starter · #17 ·
I'm using the same stuff as you, though I'm actually using the older s9 plus. I'm also using the Obdlink MX. Working fine for me. I can download maps to my phone and open them and manipulate them. I can also push those maps to my Triumph.
What I can't do is read the current map that is on the triumph. They have listed that exhaustively on their website that that is a current limitation because support for these just started in the last month.
The obdlink MX plus just started support yesterday, so you also may want to make sure your app and everything is up to date.
Support for Windows died in 2016. Frankly I'm glad it did because it was old tech. That said if you really want you could always take the map open up Windows and edit it, then push it to your phone then push it to your bike.
I definitely understand that it can be frustrating to use a small device like a phone, I briefly considered getting a tablet just to do this. But you can do it with your phone once you get the hang of it just fine.
Its been a few years but I have tuned a few bikes on the dyno with TuneECU. That's a good refresher though. What I am finding though, is that TuneECU doesn't have the ability to open a map and write a file to the newer Street Twins... so all I get are the basic diagnostic tools... :-(
Discussion Starter · #19 ·
Well considering I just posted a screenshot of me digging into a Street Twin map.......
Just remember it can't read what's actually on your bike right now. But it can push the file that you currently have open to your bike.
How? I have the latest TuneECU app on my Android phone, I can open it and connect to the ECU just fine. There is no map button, I see no way to load or open a map, edit it, or push it to the ECU.
I can't open a map, that's the issue. haha
1 - 20 of 680 Posts
