1 - 3 of 3 Posts
Does anyone have a picture of the correct positioning of the w clips to install a headlight? I have the clips installed but the light now won't fit back into the main light bucket.
Administrator
Welcome to the forum!
The folks with the knowledge and experience with the classic Triumphs will be found in the Classic, Vintage, and Veteran forum. Introduce yourself there and engage the members with your inquiry.
http://www.triumphrat.net/classic-vintage-and-veteran/
Best of luck.
Cheers!
Hi,
Welcome to the Forum. :)
Usual problems are either they're installed upside-down, so the bottom of the 'W' sticks up instead of being between the rim and the lamp, or you've installed one or more of the shonky ones.
If you can post a picture of yours, we should be able to spot the problem.
1 - 3 of 3 Posts
