Its not the 418 or 412 or whatever model you choose,its the "regular" or "heavy duty" that decides which springs they send on the shocks.Progressive has about a 1/2 dozen different springs available so you can fine tune them to yourself later if you need too. I`m at 200lbs fully dressed to ride and very rarely bottom the "regular" set I run. My springs are a 75/120lb set.
Wow! that thing is badass. Nice job.SWEET !
but that was 2" ago.
My seat height is 26",so I see the road even closer up than you will.
