Kit is in the mail (thanks Coweta Custom Cycles!). Is there much to the install? I am no genius with a wrench (or a soldering iron) so I was wondering if I should get my dealer to install it. Any thoughts? :???:
Just follow the good, explicit directions in the kit.
It's straightforward, no soldering required, just a gentle touch and some fidgeting with parts. You plug it into a connector in the headlight shell. Your '06 will not require the "removal of the tank" part of the instructions.
Try to route the wires and cables gently so they "naturally" sit in a good position.
Edit: Sorry, I should have typed '07.
[ This message was edited by: Baltobonneville on 2007-01-05 18:25 ]
