Why can't Triumph introduce the new clocks on the Tiger range to the S3 range for 2007? The one lack on the '05/'06 S3 was that of a decent fuel gauge, which has now been reported added to the instrument panel on the new '07 Tiger!
If I were Triumph, I'd change the specs a little though:
1. Ditch the bar graph for the temperature gauge and give a direct Centigrade/Fahrenheit read-out
2. Add a fuel gauge. Not Bar graph but in percentage terms.
3. Add a digital gear indicator
While I'm at it, I'd also add:
4. A chipped ignition key as standard;
5. Fully adjustable front forks (and not the partial arrangement presently offered);
6. User-Adjusting collar on the rear shock. Better quality shock as well!
7. Radial Brake Lever (as is standard on the 675), with less lever travel;
8. A better seat with more forward support;
9. Rear-view mirrors that work!
10. Hydraulic clutch lever.
11. Gear-shift lever with no positive stop in 6th (as per my BMW -- much easier to tell that you are in top! -- what is the technical term for this?)
Can any one add (or argue against) my wish-list?
