Hello!!
Please, somebody knows if I can use a standard Triumph USB to ECU cable with TuneEcu in my Daytona 955i 06?
Thanks!!
Thanks for your answer!
I have read the manual and I saw that I need a: "Cable for connecting to the dedicated 16-pin diagnostic plug of the Engine Control Module (ECM): USB/OBDII cable with FTDI chip set and associated CDM (D2XX) ver. 2.06.00 drivers or higher." but here in Brazil this cable is more than USD$50.00 to use with Audi and VolksWagen...
And my workshop has an original Triumph cable, so I'm just curious if I can use this cable with TuneEcu...
Thanks!!
Hi,
I never had the chance the original Triumph cable test.
Try it out.
BR, Tom
Thanks!!
I assume then Brazilian is referring to the Actia connection cable which is serial and not usb as described. Don't think the Actia cable can be used.
