Compressing the forks during transport normally does not cause an issue unless you compressed them all the way and for a long time. Even then, I've seen bikes go cross-country without issues, so that may not be the cause of your problem, but it's a starting point. There may be a totally different reason, including plain-old mis-assembly at the plant, which in your case might be the more likely scenario.
Neanderthal
