The shifting on my 97 Trident (just bought a few weeks ago) doesn't seem as smooth as it should, and the fluid in the mc reservoir is a little dark. Consequently I'm going to pull the mc apart and open up the slave cylinder and clean/service everything. Any suggestions out there for OEM parts or compatible parts to use. I've read that some Kawasaki master cylinders are identical and that I might be able to use them...just not really sure. I've got the diagrams from Bikebandit.com and assume I will need the piston set, but probably not the diaphram for the mc and the piston set for the slave, as well as new banjo washers all around. Am I missing anything??? Anyone got parts numbers or cross references??? thanks in advance
Bernie
I might have an extra rebuild kit lying around. I'll see if I can find it if you want. Might be a good excuse to get together since you're right around the corner....
Hey thanks Jamie. Let me know what you want for it if you find the rebuild kit, and what type of beer to stock up for you!
Bernie
