I think of this thread fairly often, it's changed my relationship with my front brake. I've been overusing my rear because it doesn't cause fork dive. Folks told me not to, but I knew better. Also thought the DMV motorcycle manual was wrong when it talked about pressing on the right grip to go right.
Anyways I'm on a tour right now and coming down through Iowa I was thinking I don't have much opportunity for trail breaking at all. But Lord when I hit Missouri, I don't know what I'd do without hanging onto that front brake a little bit longer. Fast unfamiliar roads with good pavement and tight curves you can't see through. Maintaining some contact with that front brake into the corner can really help a lot. Trying to do the same with the rear doesn't work nearly as well, seem to give up much more handling that way.
Now I'm realizing the trade-off with engine braking too. Think someone talked about that earlier. If the revs are high then letting off the gas bleeds enough speed that there's no need or ability to get on the brakes at all. Think that's why I'm trail breaking down here more, going through the corners faster and therefore in a higher gear and it's working better.
Good roads down here to practice on. Gonna try it out in the Appalachians next ?
