Interesting analysis of trail braking, making some good points. I think the assertion that more rake changes the direction of forces on the tire is completely incorrect. Inescapable and inflexible laws of physics don't allow for such "magic". I'd also challenge your conclusion. You may have some limitations due to having less precise control over brakes, less powerful brakes and different tires on older bikes but these limit braking under all circumstances, not only trail braking.Hi Trumpkin
‘Not for us’ is the phrase that comes to mind, it’s a modern technique for modern bikes:
Tyres:
You will be braking/steering and leaning at the same time, you need the tyres to be sticky and preferably getting progressively stickier towards the outer edge, you also need pliable sidewalls to ‘increase the contact patch under load’. Unless you have upgraded to radial tyres then you are at much greater risk of the front tyre sliding away. The thin Cross ply tyres fitted to Classics just don’t cut it for trail braking.
Brakes:
You need good feedback to the lever and fingertip control, the standard wooden paddle ‘on or off’ disk brake fitted to T140’s does not give you enough control, it it will be so easy to approach the wheel locking point without noticing. Self servo drum brakes-no chance far too aggressive .
Unless you have made some serious upgrades to the front brakes, standard Classic Triumph brakes they just don’t cut it for trail braking.
Rake:
One of the fundamental principles of trail braking is to use the downforce created by braking to increase the grip of the front tyre. The long rake of these old frames will tend to push the brake forces more froward, rather than downward like steep head angled modern bike will do. So instead of pushing the tyre into the ground, the tendency is to push the tyre forwards, making it skid. Classic bike frames just don’t cut it for trail braking.
Trail braking is for R6’s, etc. Modern sports bikes-even then many sports bike riders have been down the road on their arses trying it. You also need practice; perhaps if you can do 10 stoppies in a row, with the rear wheel at least 3 feet in the air, then you are ready to try trail braking to increase your corner speed. It can be done, but you might find ‘slow in fast out’ might be a safer and quicker riding technique for classics.
Good luck
let me know where you want the flowers sent>
Regards
Peg.
If you are going slow enough into a corner, you don't need to brake at all of course. However, for a normal corner, I would suggest practicing gently easing off braking as you add lean until it becomes your normal practice. Also, in a hard/fast turn (not necessarily on the track) try not to complete easing off the last bit of brake until you are beginning to slowly open the throttle.I didn’t realize I was trail braking until I started reading threads on it, then I had to actually think about what my technique really ,because I don’t think about it. I’m not dragging my elbows either, I don’t ride fast. I think the slower you’re going entering a corner, the less you would trail brake because it isn’t necessary to scrub speed mid corner.
I don't know either, until I actually read one of these threads I always thought it referred to dragging rear brakes, I guess because trailers are in the rear :dunnoIt is still not obvious to me why the word "trail" is used?
That's not how I think of it. I don't think I enter the corners any faster really, just sometimes I remain lightly on the front brake and off the gas as I enter a corner I can't see through, to give me more options once I can see what's past the apex. I use it as more of a safety thing than a performance thing.Is it something to do with getting every last millisecond in a race of high preformance bikes on a racetrack? If so I don't see what it has to do with our old bikes on the road, if you are doing that then I think you are a dangerous road rider.
You do not know what you will find round that corner, if you are already 100% committed you will have no controllable options available to yourself or another person. That is irresponsible. That is what racetracks are for.
It seems you are challenged with reading and comprehension as you admit. Try reading the whole thread and opening some of the links to Youtube and you'll see a fairly consistent endorsement of the technique for safer riding.I have seen this thread for some time, but took no interest in it because I thought it was something to do with trail bikes.
Now I realise it is to do with use of brakes on road bikes. Homer "Doh".
The method seems to be what any experienced rider with commonsense would use, that you can only brake most heavily in a straight line and must be much more careful with use of front brake especially at angles of lean. What is new?
Please enlighten me on how changing the direction of the input force does not change the direction of the resultant reaction from the contact patch, I would love to know.Interesting analysis of trail braking, making some good points. I think the assertion that more rake changes the direction of forces on the tire is completely incorrect. Inescapable and inflexible laws of physics don't allow for such "magic".
Why do you think it’s a new concept to us, just because you have blundered onto a classic forum, don’t assume we are all luddites.I'd also challenge your conclusion. You may have some limitations due to having less precise control over brakes, less powerful brakes and different tires on older bikes but these limit braking under all circumstances, not only trail braking.
Trail braking may be a new concept to you but it is not a modern skill that only applies to modern vehicles. It is as old as the invention of brakes.
The front tyre doesn't know what angle the forks are at. It experiences forces due to weight in the vertical direction, braking in the fore and aft direction and cornering forces dependent on speed, corner radius and lean angle. Changing the rake of the fork may affect how some of the forces affect the suspension or steering head but not the tyre.Please enlighten me on how changing the direction of the input force does not change the direction of the resultant reaction from the contact patch, I would love to know.
I always thought Newtons third law, trigonometry and vectored forces were ‘magic’ thing that could not possibly be understood, best I stick to cooking, cleaning and painting my fingernails.
I assumed no such thing. I feel into the trap of trying to correct something on the internet. I should know better. Sigh!Why do you think it’s a new concept to us, just because you have blundered onto a classic forum, don’t assume we are all luddites.
Peg.
You did better than me, I thought that was a misprint. 6,000 miles later I finally got some training and realized what counter-steering was. That helpedThe same as 40 years ago when I first read about counter-steering in the gov't's motorcycle rider's instruction material for getting my motorcycle endorsement on my licence...
It wasn’t trying to correct something on the internet, it was slipping in a condescending phrase into you original post that provoked a well deserved reaction.I assumed no such thing. I feel into the trap of trying to correct something on the internet. I should know better. Sigh!
My nails look like a relief map of the moon, the fashion here is to paint white tips on the nails, I have ancient Triumphs so I get black nail tips :frown2:Your nails look fine I'm sure.
The above is perfectly true for a rolling wheel and suspension, but please consider that the relationship between the wheel and forks change under braking.The front tyre doesn't know what angle the forks are at. It experiences forces due to weight in the vertical direction, braking in the fore and aft direction and cornering forces dependent on speed, corner radius and lean angle. Changing the rake of the fork may affect how some of the forces affect the suspension or steering head but not the tyre.
.......When you couple the classic bikes lower tyre loading with low feedback early design hydraulic and self servo drum brakes, plus low grip/low sidewall flex tyres (There is a strong rumour that DuPont stole the formula for Teflon from the Avon SM tyre compound). You have a good recipe for impending doom while trying to brake while leaned over......
Magic? Not meant that way - sorry!Hi Slarditbartfast
I didn’t think I would find someone with a profile name stranger than mine:grin2:
Stick with a rubber pad -like it. Still disagree with the analysis, however. Forces are not somehow directed straight along the forks. In your analysis you are suggesting that (in an extreme case) horizontal forks would result in tyre forces as if the bike had no weight and vertical forks would result in tyre forces as if the bike was not braking. Forces at the steering head are related to the weight and inertia of the bike. These will be transmitted through the forks (regardless of their angle) to the contact patch of the tyre. If the wheelbase and centre of mass of two bikes are the same, and they are travelling at the same speed, braking equally hard, the forces at the front and rear tyre patch will be identical. Different fork angles or suspension design may change how the bike handles but they can't change the forces at the tyre unless they change the wheelbase too. I owned a GTS1000 for many years. It has no forks in the conventional sense and all braking forces are directed straight into the front swingarm. The bike still has weight (a lot of it) however, and while the feel and performance of the suspension is somewhat unique, the tire sees the same forces (and trail braking works just the same as does not trail braking.)The above is perfectly true for a rolling wheel and suspension, but please consider that the relationship between the wheel and forks change under braking.
Under heavy braking close to or at wheel lock, you can consider the wheel as an extension of the fork. Visualise it as a stick with a rubber skid pad on the end, because this is how it will act.
As the brakes back off this concept reduces progressively until we are eventually back to the tyre rolling free and not knowing what angle the forks are at.
If we go back to the stick with a rubber pad on the end visualisation at the wheel lock position. If you hold the top end of our virtual stick close to the ground and push forward, the rubber pad will skid along the ground. If we now hold our virtual stick at a steep angle it will try to dig into the ground.
This is how the forks and wheel will react during braking.
The tyre contact patch under braking will push forces into the ground, force has two properties magnitude and direction, force is a vector quantity. The magnitude is varied by the resistance supplied by the brakes, the direction is determined by the angle of the forks.
The equal and opposite reaction from the ground will push back along the fork, the force will be used to a) retard the bike and b) transfer load on to the fork. The proportion with which this is shared out depends on the fork angle (low stick vs high stick).
A steep fork angle will load the tyre more than a shallow angle, the grip of the tyre results from pressure x contact area x coefficient of friction between the two surfaces. The pressure x area effectively cancel each other out, so grip can be thought of as force x CoF.
A steep angled fork will give a greater percentage of force to tyre load, resulting in more grip, allowing more brake force to be applied without skidding.
As I noted earlier, all these modern advances allow harder braking under all circumstances, including while leaned over in a corner. They may also give better feel, allowing you to trail brake smoother and closer to the limits. Trail-braking as a discipline and topic for discussion may also be "modern" but the practice is as old as the first two-wheeled vehicle with brakes. I had never heard of the concept when I started riding bicycles in the 60's or motorcycles in the 70's but I can assure you I was doing it. It was only when I re-started teaching in the early 2000's that I encountered a curriculum that encouraged NOT braking in a corner (for beginners on bikes with powerful brakes.)Sports and modern bike react to differently to braking than classics (or cruisers) due to their suspension geometry. You can brake harder and deeper with a more modern setup, due to the high grip tyres having a greater a load imposed upon them.
(I have not even mentioned crude suspension that fails to keep the tyre on the ground half of the time.)
At one time trail braking was considered an advanced technique, for good reason.
Advances in tyre/suspension/brake/frame and tyre design now mean that it now a mainstream riding technique.
The way we ride is changing.
True, although I don't think many people will actually activate ABS while leaned over in a corner. Unless you're on the track, trail braking at the threshold of tire grip in a turn is most definitely a very advanced practice, requiring great skill and optimal track conditions. However the application of SOME trail braking by street riders under normal road conditions is and was a relatively basic skill, requiring only moderate finesse of the controls, regardless of whether on a modern sport bike, cruiser or vintage machine.The one thing not mentioned so far in this thread and possibly the greatest safety advance since the crash helmet, compulsory ABS (in Europe at least) if you mess up on a modern bike, there is a pretty good chance the bike will rescue you. The old clunkers will let you eat dirt.
Regards
Peg.
