1 - 16 of 16 Posts
· Premium Member
2016 Diablo Red Thruxton 1200 R
Sweet build my man! I am sure it will b fun on the track with the right set up. Scrambler arrow pipe set up will look sweet on your Thrux and definitely won’t scrape the ground…lol I have had many D & D,s over the years on my bikes, I like, some of my all time favorites. a Single D & D pipe sound great but when u run a dual set, oh yeh!….FTG
· Premium Member
Track day prep continues.
I ended up buying a Calfab Aluminum Swingarm which is a truly awesome piece of gear. It does need seals, so those were ordered. It also doesnt have a chain wear guard
Automotive design Bicycle part Automotive exterior Carbon Font
I recently bought a 3D printer and printed a chain guard for it and a few other parts
Rectangle Font Parallel Automotive exterior Diagram
Wood Musical instrument accessory Flooring Wood stain Floor
Bicycle Tire Wheel Crankset Bicycle tire
The chain and sprockets have been converted to a 520 setup
I was able to take it for a test ride yesterday. However the new exhaust is a hard no for road racing. And will have to look for a new setup. The ergos are terrible as it sits.
Tire Wheel Fuel tank Automotive fuel system Vehicle
Tire Wheel Fuel tank Automotive fuel system Automotive lighting
· Premium Member
Discussion Starter · #8 ·
That’s hard to come by these days. I’m trying to piece together a crank and pistons to get to 988. Was it a tpusa kit, what cam profile did you use?
Yeah it was a TPUSA built motor. I bought the motor used as I blew up my first one. So not 100% sure which cams it was
there is a company called bonneville performance which builds crate motors
· Premium Member
Discussion Starter · #9 ·
Had to get rid of the Arrow Exhaust because of the terrible ergo problems it created. Ended up going with the British customs 2-1 predator shorty. Had to hack up the kickstand a bit to get it to fit. But gave it a test ride on the roads and I think it’ll be my best option, at least for the near future.
Tire Wheel Vehicle Automotive fuel system Fuel tank
· Premium Member
The exhaust looks flowing and tucked in nice, should have the clearance u need and I bet that 2 into 1 with the shorty pro sounds good and give u some performance back pressure.
well put together Frankenstein bike in a good way, put together with a little of this and a little of that and “Bam” u got a track Bike. I Like, wish I could take it for a spin!…FTG
· Premium Member
Discussion Starter · #11 ·
Well did a couple sessions at NCBike on the Thruxton today. The front suspension is in need of some tuning. I got it a little better, but certainly could get a pro to look at it. Front end confidence was very low. Its also geared a bit short, so will need to fix that before going out next.
Last session of the day I had a HUGE rear slide. So suspension all around probably needs some love
Ncbike Triumph Thruxton
· Premium Member
Great pics my man, thnx for sharing!
I was checking out your 88’ RZ350 bio. wowowow! I Like, anything crossed with gsxr components like your 1000 Fr end and the rgv250 swing arm is so cool. Back in Cali when I use to shred Hwy 9 any chance I could get behind a 2 stroker like the RZ i woukd get all up in their tail pipe just to inhale the spent gases for a while, so addicting….lol…FTG
· Premium Member
Discussion Starter · #14 ·
I took the RZ out over the weekend as well. It’s an absolute ripper
Tire Helmet Wheel Sports equipment Motorcycle
Tire Helmet Sports equipment Wheel Sports gear
Tire Wheel Helmet Vehicle Sports gear
Helmet Tire Wheel Motorcycle Sports gear
Looks like a great experience; I’m going to be at NCBike for N2Track day in April 2023 on my basically stock 1200 RS Ton Up edition; should be a hoot on this bike. May see you there if you’re going.
1 - 16 of 16 Posts
