I should have spotted this earlier, but didn't.
I have what was a 724cc TR7RV. I bought it as a non runner. I rebuilt it last winter, and it runs very nicely. The alternator charges at maybe 14V and the battery is never flat. It starts first or at worst 2nd kick. It's as fine as I can tell.
Just fitted a new primary chain and an engine sprocket (see my posts in the What I did today...thread).
On fitting the stator I noticed that the rotor was protruding out of the stator on the sprocket side, by maybe 7 mm or so. I now think that's how it's been since I rebuilt it because I didn't notice. However, it runs fine, and charges, so the rotor protrusion does not seem to affect the AC production - but it cannot be right.
Checking the new Harris engine sprocket the depth from the outer face to the inner face on the outer side was about 0.8mm greater than the sprocket I've just taken off. The bike came with 2 distance spacers between the sprocket and the rotor, totalling about 13mm. Checking the parts book, there should be one spacer, and that should be 1/2" or 12.5mm. So, I have 2 spacers where there should be one (but the same total thickness), but more importantly, I think the rotor is maybe 5 to 10mm inboard of where it should be.
Looking at the photos, you can see a clean section and a slightly stained section of the rotor, where that stained section has been running inboard of the stator.
That can't be right. I can add spacers to move the rotor outboard so it would be better.
I don't understand how the rotor can be so far inboard and yet the parts all seem to be what they should be.
The new sprocket lines up apparently perfectly with the clutch, and the ends of the splines on both crank and sprocket are co-incident. I think the sprocket is located where it should be. The engine and clutch rotate apparently perfectly. It all seems OK.
The stator is I think where it should be because the stator mounting studs locate the primary cover where it should be - no excess stud length. It all fits.
I'm wondering if this is a 724/744cc issue and the crank was modified between the 2 versions, and the rotor location changed and previous owners have changed parts and I'm trying to work out what should have been.
I think this is easily fixed by spacing the rotor out a bit, but does anyone have any thoughts on this conundrum?
Thanks, Andy
Thanks, Andy
