Hi tr6rvrider, Depending on supplier the viton can come in various colors. Raber's sold brown ones. I've seen green also.
In general viton is made in many different colors. I've worked with viton seals for years at work as manufacture introduced viton seals. I can say I cannot feel or see a difference in viton to the other common oring rubbers. The silicon based rubbers are generally softer to the touch. So be careful to keep known viton seals separated & marked as needed with string tag or the like. Viton lasts many times longer than normal seals.
When in comes to viton we are at the mercy of our parts vender & their supplier. So we must think about how trustworthy our vendor is. Most Triumph vendors have ebay presence. Do your home work on eBay sellers to be sure. If a trusted seller doesn't specifically state it's viton, don't buy it without verifying from seller it's viton.
What to have a leaky motor, by a generic gasket kit such as Emgo. Flip a coin as to how long it will stay leak free....
Viton is a costly material that is worth every penny. I piece meal my gasket kit getting what I perceive is the highest quality gaskets & seals from various sellers. I hate leaks & am very picky about my seals & gaskets.
You're probably already together, but the head can have sharp/rough edges & surface where PRT goes. This can scratch, cut, catch oring & twist, distort it. It's good practice to smooth lead in of bore & the sides of bore to give oring best chance of sealing. Same with OD of tappet block where PRT passes over.
Don
