i bought this bike last year, frame &eng no tr6p du75218. bike has had sum butchering but overall in good nic. advance unit springs are fingerd.sum one put a long screw thru points plate to stop full advance. would start ,but run like a hairy goat. wiring was shot,so i redid wiring,then read post bout spg on here, now gonna rip it of and do spg .clucth is suss, bit sloppy in the wrong places. have done a few things to it, a lot more to go.
the exhaust stubbs are welded in,, is that normal? has had gearbox spedo drive cut off and taken from rear wheel.
Sharp bike! You just need a front fender!
