This might be a dumb question, but, do Tourances spec the same pressure as Annakees? Or do they run at a lower pressure? 36 psi front and 42 rear are the standard for Annakees, but the Tourances say 42 is max on the rear sidewall info. They are at 26.5 front and 31.5 rear from the dealer right now.
Block
Block it all depends on your riding style and how much you weigh.
You should never go by what "they" (whoever they are) say about pressures. Work it out best for you.
I ride with mine around the 30 psi mark because I go off road a bit, on road a bit and commute a bit. It's better to compromise on pressures. If I have road pressure (36 - 40) it's a bitch in the rough, and vise/versa if I have off road pressures (around 25PSI) when I get back on the road.
Take an air pump and pressure gauge with you on a ride and do some experimenting.
Mick :cool:
Thanks dudes. I actually put mine at 34/40 just to see how they feel. I think I actually like the Tourances better than the Annakees already.
Block
