Hi Gutz,
There used to be a thing called brake arcing, where the brake shoes were machined to match the diameter of the brake drum. This has all but disappeared along with the special machines that ground the brake shoes to the correct radius.
That was for people who had the money to take thier brakes to the specialists, the poor kids used the ‘street’ method.
It might just work for your T100.
From the DIY store get some 60/80 grit sandpaper with sticky backing, the type designed to stick directly to orbial sanders, or, at a push some ordinary sandpaper and some double sided tape.
Set up the brake as described by Hermit, take the wheel off the bike but the brake cable still connected.
Slacken the adjuster at the handlebar and remove the brakeplate from the drum.
Cut the sandpaper into small strips the width of the brake shoe and about 1” long -
Clean the drum and stick the sandpaper around the drum on the braking surface.
With a felt tip pen (magic marker) draw a line along the length of the brake shoe.
Fit the backplate and shoes, and the wheel spindle.
Very gently apply the brake while turning the backplate backwards and forwards.
Check the shoes often, when the line disappears you are done.
Remove the sandpaper and clean the drum.
It is quick, takes about 5 minutes so check progress often.
Your bed in distance should now be about 20 miles, not 2000.
Oh, and wear a mask, there is no asbestos anymore, but the dust still could be quite nasty.
Regards
Peg.
P.S. You will need to set up the brake again using Hermits method afterwards.
