tip over sensor
7823 Views 4 Replies 4 Participants Last post by  DirtMcGirt
where is it located...what does it look like :???: :???: :???:
If I recall correctly its under the tank towards rear of tank a squarish thing about 1/2 square and about 2 inches long. It's across the bike.
Do a search at Bike Bandit maybe you could find out more.
Dont the two round things on either side of your nose do the job??
From the service manual:
Fall detection switch - situated next to the
barometric pressure sensor, beneath the seat.
The fall detection switch will detect if the
motorcycle is on its side and will cut power to the
ECM immediately. This prevents the engine from
running and the fuel pump from delivering fuel.
In the event of a fall, the switch is reset by
returning the bike to an upright position and
switching the ignition off then back on again.
thanx bro :wink:
