1 - 2 of 2 Posts
I have a problem with checking correctly my Timing on 1982 t140e Bonnieville Twin
I dont see many like my bike.. it has a small inspection hole APPROX 30 MM DIA with a steel pointer marker that pointing at approximatly at 10 11 o clock and it at the top end of rotor
I have only two marks on the rotor and i do know which one is TDC but have no BTDC deg mark (ie: 38 deg mark?)
Q: do i set the strobe TIMING on the TDC for this particualr marker? > IM A BIT CONFUSED.... IS IT BECAUSE THERE ARE ONLY TWO MARKS ON THE ROTOR THAT ONE PRESUMABLY IS THE btdc 38 deg mark OR DO I HAVE TO FIND/CREATE AN ADDITIONAL MARK TO GET 38 DEG BTDC im not sure wher to go
sorry for yelling
Administrator
Welcome to the forum!
The Classic, Vintage, and Veteran forum is where you can connect with other classic Triumph riders and rebuilders. The folks there will have the knowledge and experience to assist you. Introduce yourself there, post photos of your classic Triumph, and engage the members.
http://www.triumphrat.net/classic-vintage-and-veteran/
Please complete your user profile so that we may see where you are from as you post throughout the forums. Thanks!
http://www.triumphrat.net/profile.php?do=editprofile
Connect with local riders in the RAT forums. If you do not see a thread for your area, please start one.
http://www.triumphrat.net/rat/
You may also find local riders and local events in the Rides and Events forum.
http://www.triumphrat.net/rides-and-events/
Please share your rides with us by posting photos of your rides in the Ride and Trip Reports forum.
http://www.triumphrat.net/ride-trip-reports/
Enjoy some off-topic and often humorous conversations in the Biker Hang Out forum.
http://www.triumphrat.net/biker-hang-out/
There is much to our forum, so please make yourself at home, browse the forums, and join the conversation where ever it may interest you. We are happy to have you here.
Cheers!
1 - 2 of 2 Posts
