1 - 2 of 2 Posts
G
So I screwed up.
when I took the engine apart I didn't take care to note which of the 3 key ways the timing gears connected to the cams.
If the engine is together, is there anyway to figure it out? or will I need to pul the top end?
Use the keyway which is aligned with the stamped dimple mark on the tooth adjacent to it. You will find the assembly to be much easier if you back the adjusters all the way off and even easier if you pull the rocker boxes.
1 - 2 of 2 Posts
