1 - 2 of 2 Posts
I just finished checking the clearance on my valves. They are all within specs. except for two, which are a little tight. Going down one shim size would put them in spec. How does a valve tighten up with time? Would it be wrong to just put everything back together and do it again in 5000 miles.
Unlike screw adjusted valves, those with shims tighten instead of loosen as they adjustment wears.
I guess it comes down to how tight is a little tight. If it is within spec but on the tight side of that you could wait. If it is out of spec. you'd be doing yourself a favor to just make it right.
1 - 2 of 2 Posts
