My bike is a 900 GT PRO should be fully equipped with the Triumph Shift Assist. For the moment I ride with the TSA off.The dealer needs to calibrate the TSA hardware unit to your vehicle. Turning on the software without the hardware installed and calibrated will throw a code when you turn the ignition on and then every time you make a gear change.
Note that if you don't have the hardware installed, the software issue can be solved by turning TSA off in the menus.
