1 - 2 of 2 Posts
One of the first mods im doing is the twin driver headlights, so both headlights will be running permanently..... Which are the best/brightest bulbs i should use?.......also im wanting to put either extremely bright or led bulbs in the small sidelight type bulbs at the top of the headlights....which would be best to get?
I have the TwinLight Driver 3 and love it, but do not run hotter bulbs. There have been a few reports of the reflector material inside the lamp housing failing because of hotter bulbs. Higher wattage bulbs are also possible to stress the OEM wiring (which the Driver 3 does eliminate). That and the relatively minor improvement you gain from brighter bulbs.
Most 1050 owners who feel the need to replace the lighting system, go to HID or Xeon.
1 - 2 of 2 Posts
