So I got a 1995 thunderbird 900, over 2 years ago and when I got it the loom was butchered, the neutral sensor was unplugged but the neutral light was always on.
The 3 clutch switch were all wired together but the bike started and ran fine. Apart from the neutral light always being on (even when I had disconnected the neutral sensor.
Then the indicators started playing up. And working interminable. I checked the fuse and the box around started melting.
So to fix that I put a separate wiring harness for the indecators in direct from the battery but used the original switch gear.
Now this is were it gets weird, I removed the tape from the clutch switch wires and found when only 2 were connected not all 3 the bike ran fine and the neutral light even when off in gear (RESULT).
UNTIL!!! Went on a 15mile run 2s up so no break neck speeds everything is fine until we stop and I turn the bike off after a coffee and smoke break jump. Back km the bike and Boom its dead! Won't start but all the lights work,
But the neutral light is off even when it's in neutral!! Tried bumping and jumping bike.
Even when I shorted the starter solanoid it did nothing,
What I'm asking is anyone shead some light on the latest problem, and second I have a trophy 900 loom and igniter (cheap ebay win) could I use that loom on the thunderbird??? Same motor?
Hello, welcome to the site.You should get over into the Triple Tech section and ask you questions - I'm sure those guys can give you a hand.
I hope you find this Triumph site to be a great place to meet and talk all Triumph bikes with a great bunch of riders.
Everyone here is very willing to help with any issues or concerns with your bike. This is really a great bunch of riders very willing to help other riders.
Cruise around the different sections and find where you fit comfortably. There are tech sections for each of the many models of Triumphs and chat sections for the same. Also we have a great classifieds section that is well worth checking out.
If you want to just hang out and shoot the breeze the “Biker Hang-Out” Chat Section will be the place to stop in.
If you haven't already please fill out your profile. It helps others to know what you ride and where on the planet you are located.
I hope you enjoy the site. The moderators are here to help if you have questions or concerns. Thanks for joining the Triumph Rat Family.
Here is a link to the rules of the site and the classifieds. I recommend that you take a few minutes to read through them.
Acceptable Use Policy
Acceptable Use Policy (AUP)
Classified Ad Rules - Read first before placing Ad
https://www.triumphrat.net/threads/classifieds-rules.578169/
Many thanks for your help, being new I wasn't sure how the site worked, iv put it in the tripe tech section
It was a early morning post as iv spend most of the night thinking about this 😂
Good luck - I'm sure they will give you some help. Friendly bunch and very knowledgeable.
