Dr Pat, but mostly Pat,
My plans to turn the Scrambler into a touring express have just hit the buffers. Earlier today I started carving up the airbox to fit K&N pods, the left side was a canter but the right side had just begun.
I had to remove the Scrambler pipes to get access to the rhs of the airbox, but first I had to pull the oil cooler to get the pipes off. I then discovered how much the Scrambler pipes conceal:
That's after one soaking in salt solution from treated roads, then the bike left for two weeks while I was at work. Bear that in mind if you use your Triumph as transport in a country that has a winter!
I recently bought a pair of Bonnie pipes, Hyde silencers and Hyde pannier frames to turn my bike into a tourer. Unfortunately there are a few wee banana skins I hadn't foreseen. The Bonnie pipe clashes with the Scrambler rear master cylinder on the right and gets muddled up with the centre stand on the left. There also seems to be nowhere to attach the Bonnie pipe's rubber mounts to the Scrambler frame. I know someone put Thruxton pipes on his Scrambler, but it doesn't matter now. I'm now abandoning the Bonnie pipe part of the project. I'll still fit the lhs side pannier frame (somehow) with a small 21ltr pannier, that'll have to do for mrs C's holiday things, I'll make do with what goes in the tank bag.
Sorry Pat, I jumped the gun in my eagerness to please, I should have shutup until the job had been attempted. I'm going to cut my losses and put the Scrambler pipes back on after I've fitted the pods. Hope you don't want to throw me on the fire, sorry for getting your hopes up
[ This message was edited by: johnyC on 2006-12-16 16:12 ]
