1 - 7 of 7 Posts
I sent an email to them 2 times - asking what they thought the compatability of their cams would be with the modifications I'm doing - 11-1 forged pistons, porting, 2mm bigger intake valves, 1mm bigger exhaust valves, billet intakes, 42mm HSR mikuni's, predators and K&N pod filters. Not asking for their "secrets" just their opinion on potential power gains with the mods being performed. No response must be their way of telling me to stay away.
John
On 2007-01-07 16:58, Hogtied wrote:
John, With all those mods, once you get that motor dialed in, she's gonna be a hot rod..
Did you look at BC's cams?
Chris
Chris - I'm going with the stock cams right off the bat - see what happens on the dyno. Cams are so easy to swap in (other than I'd need to check valve clearance with the custom pistons) that I can fool with them later if I find a set or people start make specs available.
John
G
Discussion Starter · #7 ·
I would think with the research and testing they've done so far for the 270's that they'd have something for us tooooooo....
1 - 7 of 7 Posts
