g'day
I put my '08' thrux in today to have the a set of thunderbike cams fitted and a re-tune. They have done a dyno run before they started and it put down 62hp not bad. After cams fitted they did a quick run to see how it was running and it went 68hp with not much torque as leaning straight out so the bike is still in there over night while they tune it. Just to let you know the bike has ai removed, predators,39mm fcr, air box removed. I just put the preds on i had TOR'S before, i have also ceramic coated the header pipes well worth it as it keeps the heat down. So when i get the bike back i will post the finished hp figure up.
I can say the first year of ownership of the bike has been so much fun with being able to modify it step by step and to see how each mod changed the bike. Now i hope to just clock up the kays and enjoy it for awhile now with out doing much more to it
