1 - 7 of 7 Posts
Dows anyone have any information about the suspension spring rates,supplied from factory, for the front and rear.
I usually changed front cartridges to a .95 or 1 kg/mm spring rate at the front. I can get these easily from racetech.
At the back its a different story - Ohlins dual shocks spring rates will require some homework to find the part for the right spring rate.
The R listed spring rate is:
K=8.1 N/mm
Not exactly sure what that means.
The rear is only listed as having 120.3mm travel. No spring rates shown.
K=8.1 N/mm
8.1 N/mm = .826 kg/mm
1 - 7 of 7 Posts
